2026-09-15 04:02:12
302
14
32-60 mm Pipe Routing Clips | Snap-Fit Bracket | M3 Mount
@MateuszTokarz_4351639
BOM: Printed with ROSA3D High Speed PLA Dark Blue
Taking our snap-fit design to the absolute maximum! This "mega" set of pipe brackets is specifically engineered for massive routing tasks in your workshop, garage, or basement. They are perfectly sized to hold thick PVC plumbing pipes, central vacuum lines, and large dust collection hoses.
Despite their massive size, they function exactly like the smaller versions: secure the bracket to a wall or joist using a heavy-duty screw through the central mounting hole, and push your pipe into the jaws. The oversized arms will flex open and lock the pipe firmly in place, keeping your workspace safe and organized.
Key Features:
  • Mega-Duty Sizes: Includes precisely toleranced clips for massive 32mm, 40mm, 50mm, and 60mm pipes.
  • Industrial Snap Action: The elongated, thickened retaining arms are designed to grip heavy, rigid pipes securely while allowing just enough flex for installation.
  • Heavy Mounting: Features a reinforced central mounting base to handle the substantial weight of large, fluid-filled or dust-filled pipes.
  • Clear Labeling: The exact pipe diameter is prominently embossed on the front face for quick identification.
functional
holder
heavy duty
clip
pipe
bracket
snap fit
hardware
workshop
plumbing
organization
tools
garage
vacuum
dust
collection
conduit
pvc
routing
central
